Тематический => Гитарные усилители и примочки => Тема начата: mensur от Апреля 06, 2011, 12:26:41 pm
Hi Guys,
I want to build EL34/6L6 SE power amp, but I also want to wound OT.
According to Valveheart, full calculation goes like this(for my example):
Power P= 10W(3.6K EL34-6L6SE)
Low freq response fd=60Hz
Primary Impedance Ra=3600 Ohm / 6000 Ohm
Secondary Impedance Rs=4/8 Ohm
Flux density B - 10000Gauss - 1T
According to Valveheart core dimension is determinated by the eq:
Q=sqrt( (Pout*G*10^6) / (fmin*B*Is)) - where:
- Pout is the output power
- G is coefficient of weight between copper and iron /G=1.5 - 1.0/
- f min is the lowest desirable frequency
- Is is the density of current in the wire - Ampere/sq. millimeter (1.5 - 2.5 A/sq. mm).
- B is Magnetic Field Intensity in Gs
I don't get this equation cause every time I calculate it I think it's wrong.
Here's mine example:
Q=sqrt( (10*1.5*10^6) / (82*10000*1.5))=3.5cm^2
I'm confused because of the lower equation, cause for the same input I get:
Q=20*sqrt(Pout/fmin)
Q=20*sqrt(10/82)=6.98cm^2
I wonder how they got 20?Can someone explain this to me
Q=20*sqrt(Pout/fmin) - but this applies for B-5000Gauss, and that's for HiFi, we need guitar OT, so we chose B-10000, other reason is, any power transformer core can be used, cause they are made for 10000Gauss - 1T.
So we get:
Q=10*sqrt(Pout/fmin)
Q=10*sqrt(10W/50Hz)
Q=4.47cm^2 - 6.25cm^2 core we will chosen
Primary turns:
n1=10^8/(4.44*B*fmin*Q)=10^8/(4.44*10000Gauss*50Hz*6.25cm^2)=7.2
U1=sqrt(Ra*Pout)=sqrt(3600*10)=190VAC
Np= n1*U1=1368 turns
Secondary turns:
Ns4=1368/(sqrt(3600/4))=45 turns
Ns8=1368/(sqrt(3600/8))=65 turns
Ns16=1368/(sqrt(3600/4))=91 turn
Primary current:Ip=Ia+Ia'
Ia=SQRT(Pout/Ra))*1000=SQRT(10/3600))*1000 = 52.70mA
Ia'=73mA(this is bias for tube)
Ip= Ia+Ia'=125.70mA
Secondary currents:
Is4=SQRT(Pout/4)=1.58A
Is8=SQRT(Pout/8)=1.12A
Is16=SQRT(Pout/16)=0.79A
Wire diameter:
wp=SQRT(Ip*0,001/3)*1,13=SQRT(125.70*0,001/3)*1,13=0.23mm - 0.3m wire is chosen
ws=SQRT(Is4*0,001/3)*1,13=SQRT(1.58*0,001/3)*1,13 = 0.82mm - 0.7m wire is chosen
Can someone who is experienced in winding OT's can confirm this, before i start wounding the transformer.
I do not understand English
Where are you from? Maybe you simply buy a ready-made transformer
:o
You can use google.translate.com
'm doing. ;D
By the way, he takes bad technical terms and the conversations
бамбарбия?
киргуду!
бамбарбия?
киргуду!
Ты хочеш его поставить в тупик?
пусть знакомится... окультуривается.......
Этож классика уже можно сказать наша
It does'nt worth effort, in my opinion. It's better to buy such items - too much work for suspicious sound improvements with little money saving.
Sorry, I wasn't sarcastic, I just want to find help.
I'm from Serbia, and It's much cheaper to wound transformer, over to get one from internet.
Can somebody explain how can I determine core size form flux density(in my case 5000Gs), power(10W), low frequency(82Hz)?
Here's http://www.valveheart-bg.com/index.html
Кто нибудь в курс дела может ввести?
what the transformer core is available to you?
EI75-25*25mm - 6.25cm^2
Available wire diameters?
Primary Impedance Ra=3600 Ohm / 6000 Ohm (3600 or 6000) or (3600 and 6000)?
Secondary Impedance 4/8 Ohm (4 or 8) or (4 and 8)?
You need to wind the transformer?
OR
Deal with the calculations?
That's just for 3.6K(EL34-6L6) / 6K(6V6)
I only want 3.6K/4 and 8R outputs
for primary I will use 0.3mm wire, for secondary I have 0.7mm wire.
OR
Both,I want to wind it, cause i have all ready, and need the calculations for it.
sorry, you need to go ....
later try to articulate their thoughts, to have passed through the translator
Anatoly Kotelevets' Program results:
Выходная мощность(Вт) = 10.000 W
Сопротивление нагрузки(Ом) = 8.000 R
Сопротивление анодной нагрузки(Ом) = 3600.000 R
Площадь сердечника (кв. см) = 6.250 sm2
Низшая рабочая частота (Гц ) = 60.000 Hz
Ток анода (А) = 0.140 A
Коэффициент трансформации = 0.052
Амплитуда напряжение (В) = 268.328 V
Число витков 1 Обмотки = 2290
Число витков 2 Обмотки = 119
Ток 2 Обмотки (А) = 1.118 A
Диаметр провода 1 обмотки (мм) = 0.299 mm
Диаметр провода 2 обмотки (мм) = 0.740 mm
Максимальная Инукдиция в сердечнике (Гс) = 7031.250 Gs
Толщина прокладки (мм) = 0.267 mm
Can you post the program?
mensur
view private messages
В этих программах как нибудь площадь куда провод мотать учитывается? А то сечение сечением, а вот количество места под обмотку тоже важно.
I'm totaly aware of interleaved windings, I'll take primary in 3 parts and secondary in 2.
So it goes like this:
110 windings - 6 layers of 0.3mm wire - in three parts will be 1980 windings of primary.
68 windings for 4R - 98 windings for 8R - 0.7 wire for secondary.
