Автор Тема: Собираем Mesa Boogie Dual Rectifier  (Прочитано 164666 раз)
Naigenoir
  • NASA INGINIRING
« Ответ #640 : Марта 26, 2008, 12:36:59 pm »
Работы по улучшению аппарата ведутся...  ;)
Но видно не все довольны оригиналом.
Вот с этим отзывом о ВШТ с Гарм.Централа я в чем-то согласен, простите что на инглише ...
Sound Quality : 3
My gear: Jackson USA Soloist (SL1) and USA warrior (WR1), both with EMG-81's wired at 18 Volts. Running through Rocktron Replifex into a VHT 2-90-2 (which, by the way, is the best tube Power Amp I've ever heard), which comes out of two Marshall Mode Four cabs (which I bought after I sold my Mesa Rectifier cabs).
I play technical, fast, intricate, brutal metal. I like full bodied, crisp, sensitive, tight sound that is rich in a full chord but can also really define the agressive, fast stoccato notes, and, at the same time, allow you to chunk with the grooviest of beats. (Which I actually can get close to "perfect" tone with my existing Rocktron preamp).
This can't do all of those things; only some, and not to my liking.
Ok, so much of sound is subjective, but: While I like it better than other tube preamps I've heard, but it suffers the same maladies as most tube preamps: It's FUUUUUZZZZZZZZZY and very grainy. This doesn't surprise me as, really, when you look at the physics behind how tubes distort compared to certain solid state distortions, it makes sense... but I digress.
People have mentioned this preamp to be quiet, and the cleans "shimmering". Not exactly. The clean is rather basic, only interesting if you play music where you rely on the slight clip a tube clean can give you. But it's NOT quiet in heavy distortion. It hisses pretty damn badly when the distortion is churning.
It does allow for decent thump, but that thump turns to jelly when you start muting fast staccato. Chunky stuff can sound pretty good through this thing if you like it dirty and raw, but it will never have the crisp, clean, yet blazing sounds that are required for fast intricate metal.
Sustain was ok, and saturation was "ok", but not great. It wasn't as farty as, say, Marshall heads tend to be... until you flip the Deep switch or hit the FAT button. That produced a lot of flab when playing fast.
At various points, I thought I could live with the tone/distortion, and could get certain stlyes to sound ok by themselves... but strung together as a real song, it didn't work.
Taken as a whole, I thought it sounded too grainy, "buzzy", and dirty. When I plugged back into my beloved Rocktron Preamp, the cleanliness, saturation, sustain, and edge I have always loved returned... at which point I promptly re-packaged the GP3 and sent it back.
This may be good for some styles, but those who say it can cover "everything from blues to metal" either don't know anything about fast, intricate, melodic death metal, or just haven't been fortunate enough to have owned or heard anything better (like I have).
Так что так...  :(
Когда на репе были, к нам зашел чел. из соседнего локала ... и сказал "вот этот звучит лучше, у того звук слишком грязный" показывая пальцем на ВШТ.  >:(
« Последнее редактирование: Марта 26, 2008, 12:48:47 pm от Naigenoir »
Gizma
« Ответ #641 : Марта 26, 2008, 12:39:43 pm »
Мнда... ВХТ у вас НЕПРАВИЛЬНЫЙ. Он четче, мыла в разы меньше, гейна примерно одинаково с Ректой. Говорю как про оригинал, так и про самособранное.
Азнаур а у тебя самособранное есть?*)) или можбудет... когда?
Может владелец которому ты делал на основе ВХТ пред/бошку в питере обитает... Не поленюсь - скатаюсь*))
« Последнее редактирование: Марта 26, 2008, 12:41:53 pm от Gizma »
« Ответ #642 : Марта 26, 2008, 07:17:41 pm »
Сейчас готового ничего нет. Все отсылал. Но реально, без хайгейн мода на ВХТ всего хватало... Делал как простой пред (1 канал), так и Птеру моддил.
PHosPHoR
« Ответ #643 : Апреля 01, 2008, 10:11:51 pm »
Дурацкий вопрос...Вот этот конденсатор на схемке(обвел с цифрой 1)...
Он вместе с анодным резюком образует фильтр? Так? И т.к. +Епит. по сигналу соединена с землей режет просто высокие? Или я что-то не так понял?
Я там еще в цепи сетки обвел кондер на 20 пикофарад...Он тем же самым занимается?
Hateks (S.T.A Custom)
    • ICQ клиент - 5790949
« Ответ #644 : Апреля 01, 2008, 10:31:25 pm »
Я тоже так понимаю! ::)
S.T.A Custom preamps
KurtOchka
    • ICQ клиент - 383970879
« Ответ #645 : Апреля 10, 2008, 09:45:23 am »
Шасси из нержавейки зеркальной 1,5мм, надписи сделаны лазером. Блеклость надписей из за фотика, в жизни все ок!
« Последнее редактирование: Апреля 10, 2008, 10:06:51 am от Borskh_Sergey »
« Ответ #646 : Апреля 10, 2008, 11:33:19 am »
Все хорошо, но нанесение чужих логотипов на аппарат, далекий от полной копии - ИМХО просто ханжество! Свой труд надо уважать!
KurtOchka
« Ответ #647 : Апреля 10, 2008, 11:56:47 am »
АЗГ ты прав на 100% но мне так нравится. Так что, так и сделал. Там бод лого есть кто сделал (последняя фотка :o)
Naigenoir
  • NASA INGINIRING
« Ответ #648 : Апреля 10, 2008, 02:51:02 pm »
KurtOchka  :) а для чего две большие дырки возле трансов?
Scotland_Men
« Ответ #649 : Апреля 10, 2008, 03:11:07 pm »
Дырки??? ;D ;D ;D
Naigenoir
  • NASA INGINIRING
« Ответ #650 : Апреля 10, 2008, 03:47:29 pm »
KurtOchka вот еще залил пару видео - без барабанов  ;)
Учти !! снято мобилкой, звук как в WC  ;D
Ценителям высокоскоростной техничной игры - ВООБЩЕ это качать не следует ;)
Сам характер звука, думаю, узнаваем.
25мб http://rapidshare.com/files/106344932/vid.zip.html
Удачи!
Scotland Man   ;D ну да, те что возле лампы фазика....
KurtOchka
« Ответ #651 : Апреля 10, 2008, 05:01:38 pm »
для проводов и для вентиляции :))))))))))
« Последнее редактирование: Апреля 10, 2008, 05:02:50 pm от Borskh_Sergey »
KurtOchka
« Ответ #652 : Апреля 10, 2008, 05:04:09 pm »
Naigenoir У ТЕБЯ ОТКЛЮЧАЕТСЯ feedback когда работает канал РЕД или нет?
Scotland_Men
« Ответ #653 : Апреля 10, 2008, 05:37:24 pm »
Naigenoir без обид но я думал что то отверстия а не дырки.
Я сам пишу по русски на 3 ;D
« Ответ #654 : Апреля 10, 2008, 05:47:28 pm »
Уважаемые форумчане!Большущая просьба:Кто может поделится печатками для преампа месовского?Чисто преамп и ничего более.Буду очень благодарен,при наличие свободного времени могу отблагодарить пивом.Спасибо большущее.
P.s Печатки  желательно проверенные и в спринте если можно.Спасибо!
Naigenoir
  • NASA INGINIRING
« Ответ #655 : Апреля 10, 2008, 06:31:07 pm »
KurtOchka да, я поставил переключатель, теперь его можно отключать и на канале ОРАНЖ.
И зачем такие большие Отверстия, если там всего-то 5 проводов?
Scotland Man  :) дырки, отверстия... какая разница   ;D
hateks а че в этой ветке печаток не нашел...я выкладывал.
« Ответ #656 : Апреля 10, 2008, 06:58:30 pm »
ЛЕниво рыться было если честно) Если не тяжело, выложи еще разок плизз.
Спасибо.P.s Надеюсь трафик  у тебя анлим))
« Последнее редактирование: Апреля 10, 2008, 07:00:02 pm от hateks »
KurtOchka
« Ответ #657 : Апреля 10, 2008, 07:15:34 pm »
Naigenoir там у меня проводом больше и просто что бы винтиляция была. А как у тебя успехи с чистым? А вообще feedback дает больше высоких или как?  :)
Apl
    • ICQ клиент - 61049725
« Ответ #658 : Апреля 11, 2008, 12:13:42 am »
Может и мне кто выложит преам месы , можно на мыло DulikSM@tut.by
« Последнее редактирование: Апреля 11, 2008, 12:14:10 am от ApalloN »
Gizma
« Ответ #659 : Апреля 11, 2008, 12:58:28 am »
Млин выложи плз семлы в нормальном формате! Мой комп mp4 вообще даже не пытаеться понимать*)
