Автор Тема: SansMarshall - кто уже сделал?  (Прочитано 4279 раз)
Elick
Re: SansMarshall - кто уже сделал?
« Ответ #40 : Мая 08, 2012, 11:08:15 pm »
@ armkon
OK. Make this project. This is a good, solid sound. But do not tube.
Good luck!
armkon
« Ответ #41 : Мая 10, 2012, 02:50:46 pm »
Sansmarshall with that mods you have talk before will be look like that?
http://macio.com.pl/sansmarshall/sansmarshallxxx.pdf
« Ответ #42 : Мая 11, 2012, 12:06:41 am »
@ armkon
Bypass won't work :(
Elick
« Ответ #43 : Мая 11, 2012, 01:10:52 am »
@ Denn
Млин, ну и схемы рисует этот англоязычный джентельмен... Мне даже лень разбираться.
armkon
« Ответ #44 : Мая 11, 2012, 01:26:06 am »
Yes i don't know why, i cant set that bypas to work... whatever i'm doing it wont work right...
I want to make a new project on the base of this distortion, becaues i see potential in the samples from Denns website.
I got a Question:
If i will put a 2 realys on begin and end of it for make a selectable clean channel (different preamp, i dont know for now what preamp it will be the best for it and still searching) and dirty channels - this preamp same switchable with relays. And then bufor on the output to work as a preamp in to the small power amp?
channels in dirty mode will be same switchable with relays...
What do you think?
I want to make a little practise amp with 4 channels and usable sound - clean cruntch rythm lead for practise, i dont want to spend to mutch money for tubes and trafos etc. I don't need the tube sound...
Any sugestion for some good sounding clean pream?
« Ответ #45 : Мая 11, 2012, 11:04:14 am »
Never say that here! >:(
 ;D ;D ;D
http://diyfactory.ru/index.php?option=com_content&task=view&id=89&Itemid=47
« Ответ #46 : Мая 11, 2012, 02:55:01 pm »
Your modded version has clean (bypass) output taken of drain of FET (behind the coupling cap). But this point is muted at drive mode. You have to rebuild a schematics of muting section.
« Ответ #47 : Мая 11, 2012, 08:27:07 pm »
@ armkon
About huge SS Preamp... see ideas here - http://www.carvinservice.com/crg/schematics/s03001M.pdf
drow
« Ответ #48 : Мая 15, 2012, 12:09:15 pm »
Какой транзистор во входном каскаде необходим?
Имеются: КП303А/Г, J201, BF245C
Проблема в том, что при отстройке ~5.2-5.4В на стоке, сопротивление на истоке получается довольно большим и уровень усиления колеблется около 1 и меньше.. Входной повторитель был убран(байпас напрямую вход-выход), со входа идёт:
1М на землю, 22н - 1М на землю, 1к - затвор транзистора. Дальше по схеме.
Печатка
http://img687.imageshack.us/img687/7769/sansmarshalllayout.png
« Ответ #49 : Мая 15, 2012, 12:12:25 pm »
@ drow
Вообще говоря, ни один из перечисленных ПТ не подходит. На оригинальной схеме указаны варианты, они - строгие.
Можно попробовать твикнуть под J201, но в ПТ я не силён, тут пусть кто-нибудь из коллег подскажет.
Серж
  • Воля и Разум
« Ответ #50 : Мая 17, 2012, 08:21:28 pm »
Вот кстати, я немного переделал печатку которую выложил Denn, под обычный корпус, несколько уменьшив размеры платы. Собственно, сам буду делать по ней. Может кому понадобится. По схеме сверял- всё совпадает. Вот ссылка на  архив  http://www.onlinedisk.ru/file/878828/
 А, кстати, там посередине платы, на месте там где был футсвич- я дорисовал дорожки под стабилизатор  L7809 на 9 В и сглаживающие кондёры по 100 мФ и 0,1 мФ
« Последнее редактирование: Мая 17, 2012, 08:24:26 pm от yierbsh383hg »
drow
« Ответ #51 : Мая 25, 2012, 02:23:52 pm »
@ Denn поставил КП303Б, вродь стало лучше.
Всплыла другая проблема - никакой реакции на переключение режимов перегруза. Т.е. переключатель работает(замыкал и вручную), тестер показывает изменение сопротивления об полпитания, а в звуке разницы никакой. Может кто посмотреть печатку в чём мб трабла?
Дорожки платы сфоткать адекватно не выходит(на телефоне качество ужасное), проблемы с флюсом нема т.к. весь смыт(паяю с скф).
Вот печатка картинкой(продублирую из постав выше)
И сам файл
http://ifolder.ru/30707754
drow
« Ответ #52 : Мая 26, 2012, 05:48:06 pm »
Подсказали косяк - в обратной связи D2.2 кондёр действительно 2.2мФ? Ставил 2.2нФ, что судя по эмуляции сильно разливачется с 2.2мФ
Серж
  • Воля и Разум
« Ответ #53 : Мая 26, 2012, 09:12:37 pm »
Всё, наконец то спаял я этот Sens Amp \Marshall (по схеме Denna) !!! Примочка как ни странно, заиграла сразу. Звук очень понравился, даже лампой пахнет немного  :D . Кстати, это моя первая работа с экранированной платой , специально решил начать делать двусторонние платы для примочек. Результат очень порадовал - шумов нет, но примочка сама по себе очень чувствительная, и на большой громкости и при максимальном гейне заводится. Думаю, когда всё соберу в металический корпус, самовозбуждение уменьшится.
  Ещё пару слов о звуке. Тёплый, яркий, сочный перегруз больше похожий на добротный овердрайв, чем на дисторшн по характеру обертонов. Сустейн тоже порадовал, звук не затухает долго, вообще примочка сама по себе очень отзывчивая, как отмечал ранее кто-то здесь.
   Пока нет кнопок ДПДТ, которые я поставлю на выбор каналов ( Clean \ Crunch \ Rhytm \ Lead ) . Я немного изменил схему переключения каналов, для ножных футсвичей - их у меня будет 4 :  1- байпас , 2 - Crunch\Clean , 3 - Rhytm\ Lead , 4- Marshall\ Mesa ) . Так что в основном пока тестировал в режиме Crunch , Mesa. Доделаю до конца, когда куплю кнопки DPDT.
  Вот пару фоток, за качество извиняюсь, так как пока нет нормального фотика.   :P   Оформление в корпус планирую в ближайшее время.
http://www.onlinedisk.ru/image/883375/Фото009.jpg
http://www.onlinedisk.ru/image/883376/Фото010.jpg
http://www.onlinedisk.ru/image/883377/Фото011.jpg
« Последнее редактирование: Мая 26, 2012, 09:17:24 pm от yierbsh383hg »
Серж
  • Воля и Разум
« Ответ #54 : Мая 26, 2012, 09:52:54 pm »
  Можна поподробнее об этом ??? У меня та же проблемка- на переключение каналов Rhytm\ Lead примочка реагирует очень слабо....
drow
« Ответ #55 : Мая 26, 2012, 10:14:13 pm »
@ Серж 2.2нФ эт был мой косяк. Там верно по схеме 2.2мФ.
А вот почему разницы между Rythm и Lead нема - сам не пойму ;(
Серж
  • Воля и Разум
« Ответ #56 : Мая 26, 2012, 10:19:38 pm »
Там скорее всего разница ощутима при режимах Crunch и Lead ( добавляется больше высоких частот) , так что можна спокойно ставить один футсвич на этот режим, а не два, как я хотел раньше.
drow
« Ответ #57 : Мая 28, 2012, 07:06:51 pm »
@ Серж Хм.. по разнице в режимах Rythm и Lead кажется понял. Т.к. фактически различие только в усилении 1ого каскада, то разница в том, что в режиме Lead происходит большее усиление высоких частот.
В принципе для более явной разницы можно попробовать заменить 11к(после 22нФ) на 5.6к, а 11к дальше на 15к. Таким образом усиление по этим частотам в режиме Rythm будет примерно тем же, а у Lead'а будет ещё больший подъём середины-верха.
Серж
  • Воля и Разум
« Ответ #58 : Мая 28, 2012, 10:23:55 pm »
   В принципе, эти режимы меня устраивают с головой, ничего в схеме менять не буду. Понравилась глубокая регулировка средних частот. Особенно нравится звук, при положении этого регулятора около 8-9 часов, ближе к минимуму. Тогда ещё немного добавляется как будто фазера , типа немного авто квакуха. Не знаю, или у тебя такое наруливается, можешь поэксперементировать.
« Последнее редактирование: Мая 28, 2012, 10:24:23 pm от yierbsh383hg »
DIM
« Ответ #59 : Июня 02, 2012, 10:59:55 pm »
Также на свободном ОУ можно сделать буфер для чистого после ПТ (с Ку<1, чтобы скомпенсировать "ненужное" усиление каскадом на ПТ).
Интересная идея! Подскажите как реализовать её на практике. Мне пока не по силам решить эту задачу :'(
