Автор Тема: Собрал тремоло Tremulus Lune  (Прочитано 4333 раз)
Sstriker
    • ICQ клиент - 392114616
Re: Собрал тремоло Tremulus Lune
« Ответ #20 : Октября 04, 2010, 08:17:53 pm »
Может что-то и меняется, но только не щёлчок  ;D
На сайте авторов педали FAQ нашёл:
Q: My tremulus lune that I built is clicking (or popping or ticking) to the rate of the LFO. Everything else works, but the clicking sound is annoying! What can I do?
A: First off, check, double check all your soldering. A simple bad joint can leave a filter cap out of circuit and cause this problem. Or a reversed electrolytic (blue cylinder) cap will do it too.
Next, try to locate the problem: put a 0.1uf cap temporarily across the gain pot (or gain trimpot). If the clicking goes away, then you've probably got high-frequency oscillation in the audio stage: (i.e. the problem is the photocell or the TL072 circuitry).
If it doesn't go away, its probably the LFO circuit or the powersupply (i.e. the 4558 or powersupply).
PROBLEM IN THE LFO CIRCUIT:
-Try replacing the 4558 IC.
-Try replacing the 10uF cap by the 4558.
-Try increasing the value of the LFO smoothing cap. It's the .0l uF (103) capacitor across pins 6 and 7 of the 4558. Go up to about .022 uF, .033 uF, or even .047 uF until the ticking goes away. The only thing with is that it will limit how fast the LFO can go. The waves kind of smear together at faster speeds.
-If the clicking only is heard when Smoothness is turned to square wave, then put a 0.01uF cap across Smoothness 1 and ground.
PROBLEM IN THE POWERSUPPLY:
If you're using a battery, try using a power adapter or vice versa.
If that doesn't work, then solder a 100 uF capacitor across the power supply rails directly underneath the 4558.
If you're using an external gain pot instead of a trimpot on the circuit board, try using a fixed resistor in the gain loop for higher than normal gain (try a 10K or a 22K at first), then control the volume with a 100K audio taper pot at the output.
PROBLEM IN THE AUDIO STAGE:
Do this test to see if it's the photocell:
Set your gain pot so that the output volume is close to the bypassed volume. Now take the pot out of the circuit and measure it with a meter. If it's between 10k and 100k then your photocell is probably OK.
If the meter shows less than 10k, then the second op-amp stage is getting loaded at the output too easily (at least thats what i think is happening, anybody understand?....) Or if the meter shows greater than 100k, the feedback loop is too high in resistance, and therefore invites oscillation too easily (Again, thats a guess as to whats happening...) In either case, replace the photocell.
Make sure you're using a TL072, not a lower grade opamp. The 4558 isn't critical, you can use a TL072 for that too.
Но оно похоже применимо только если щелчки постоянны.
Estet
« Ответ #21 : Октября 05, 2010, 09:28:20 am »
Ура! Щелчок побежден :)
Прочитав пост выше, я вспомнил, что на одном из сайтов я видел схему луны, где параллельно подстроечнику был кондер 1000пик (дополнительный кондер 10нан в параллель кондеру 10нан в осциляторе картину улучшил не сильно). У меня под руку попался 2200пик, поставил его. Щелчков больше нет.
Понятия не имею, что случилось. Видимо, заваливается вместе с верхами какой-нить обратной связью или типа того :) Пусть лучше кто-нить из гуру прокамментит это.
Чтобы верха не заваливались я поставил вимовский 100пик - с ним тоже не щелкает, и звук не меняется.
DIY Forever!
Sstriker
« Ответ #22 : Октября 05, 2010, 01:09:17 pm »
Это на фуззцентрал, там якобы доработанная луна. Сейчас тоже попробую :)
Sstriker
« Ответ #23 : Октября 05, 2010, 01:33:26 pm »
Ура! Помогло!
smex03
« Ответ #24 : Декабря 10, 2015, 02:31:43 am »
На днях допаял Tremulus Lune (4558 и АОР124). Отличное тремоло! :)
« Последнее редактирование: Декабря 10, 2015, 02:32:42 am от smex03 »
« Ответ #25 : Декабря 10, 2015, 10:32:04 am »
Необычный карабас, из под чего такой?
smex03
« Ответ #26 : Декабря 10, 2015, 04:22:50 pm »
я думаю что этот алюм. корпус был из-под пусковой кнопки електродвигателя или что-то в этом роде :)
« Ответ #27 : Декабря 10, 2015, 10:02:27 pm »
Вполне оправданно, с учётом двойного вздорожания Гайнты...
Bananas
« Ответ #28 : Января 10, 2016, 09:24:00 pm »
А сабдж может выдавать усиление?
UPD
может
В смысле, спаял такую, а она конкретно громче звучит чем байпас. Это нормально вообще?
Если "да", а можно его приглушить как-то без ручки громкости?
UPD
Пишут уменьшить трим с 100К до 10К
И не подскажите ли, как должна реагировать схема на регуляцию подстроечника, который на схеме 25К? Его на слух нужно настраивать или по показателям тестера? Чего он делает-то? Написано что мол в зависимости от фоторезистора может быть до 100К. Поставил 50К, но он у меня на 10 оборотов и может из-за того, что очень медленно изменение происходит пока крутишь, я не слышу как схема реагирует на его подстройку.
UPD
ну так громкость и есть вроде.
А какая оптопара лучше  по характеристикам?
UPD
а та которая больше нравится. Короче говоря, за общую громкость отвечает сопротивление засвета фоторезистора. Если оно засвечивает на сотню Ом, так соответственно и звучит громче. Теоретически может с разной скоростью падать и нарастать сигнал в зависимости от типа фоторезистора, но гибкостью настроек самой примочки эта фигня нивелируется, теоретически.
Свою оптопару сделал из китайского фоторезистора типа 5506 и зеленого светодиода. Самое низкое сопротивление - 125 Ом, большое - 2М (это буквально спустя секунду и оно продолжает расти). Но судя по работе проверочного светодиода на схеме, фоторезистор навряд-ли успевает понизить сопротивление до 20-40К.
UPD
ну вот оно и звучит с одинаковой громкостью с байпасом при 280Ом на триме. Поставил в итоге трим 1К. Вообще подмывает отдельным потом вывести.
« Последнее редактирование: Января 11, 2016, 09:57:18 pm от Bananas »
ЗЫ GTLab 4ever!
Bananas
« Ответ #29 : Января 11, 2016, 10:10:54 pm »
И у меня самый лучший корпус корпус, который только можно представить - воображаемый  [smiley=2vrolijk_08.gif]
ЗЫ GTLab 4ever!
Bananas
« Ответ #30 : Января 12, 2016, 09:30:11 pm »
Нашел видео с таким модом. Кто-нибудь натыкался на подобное? Поиск (luna tremulus 7 knob mod) ни чего не дал.
У него еще там три режима каких-то.
ЗЫ GTLab 4ever!
Bananas
« Ответ #31 : Марта 25, 2016, 08:36:33 pm »
Запихнул в корпус. Все довольно плотненько:
А сзади резинку серую приклеил, по-модному:
А диодики поставил желтые, типа под старину, два одинаковых. Один работает когда включена примочка, второй мигает.
Еще немного фоток.
ЗЫ GTLab 4ever!
« Ответ #32 : Марта 25, 2016, 10:47:35 pm »
Запихнул в корпус
- рекомендую крепить плату на стойках, привинчиваемых к алюминиевой пластинке, зажатой между потенциометрами и лицевой панелью - и крепко, и надёжно, и никаких внешних отверстий.
Bananas
« Ответ #33 : Марта 25, 2016, 10:57:36 pm »
Запихнул в корпус
Так и сделано. На центральном верхнем потенциометре скоба-стойка (из заглушки компутерного корпуса выточенная), и на этой скобе плата и крепиться, ни каких лишних отверстий. Папа подсказал :)
ЗЫ GTLab 4ever!
Bananas
« Ответ #34 : Марта 25, 2016, 11:31:53 pm »
А подскажите пожалуйста!
Сделал сигнальный диод по такой схеме на DPDT.
А то, что там висит на входе сама примочки при байпасе, может как-то отразиться на работе в цепочке эффектов?
Просто сначала сделал так, что выходы были на одной точке и явно звук на байпасе уходил. А при таком варианте, где вход платы и вход джека на одной точке, а что если первой будет не гитара, ну и после примочки будет что-то еще? Это может отразиться на звуке?
Т.е. зачем тогда 3PDT для того что бы сделать led?
Вот есть еще второй вариант. Я так понимаю, что его смысл в отключении как раз. Но наверняка есть какое-то время реакции или что-то в этом роде. Или нет?
ЗЫ GTLab 4ever!
« Ответ #35 : Марта 26, 2016, 12:18:44 am »
Так и сделано
- препохабно сделано, если честно...
- смысл "холодного" байпасса заключается в том, чтобы на сигнальных шинах не висело ничего постороннего.
Для этого и используется 9-контактная кнопка. Хорошая альтернатива ей - схема Millenium Bypass на полевике (биполярники щёлкают, судя по многочисленным отзывам).
Bananas
« Ответ #36 : Марта 26, 2016, 01:00:38 am »
препохабно сделано...
я категорически против. "Похабно", я согласен, но "препохабно" - отнюдь. Плата занимает ту позицию, в которую была вписана при проектировке, ни чего не закорачивает, плата не болтается, пружинит слегка. Со временем поставлю вторую стойку с выходного джека. Хотя, наверное не поставлю :). Примочка - сугубо проба, первая плата фоторезистом,, первый опыт паяния ОУ, первый корпус с протравленным рисунком. Выводов море, а примочка пусть работает, посмотрю на плюсы, минусы, подводные камни.
За ответы-советы по байпасу - спасибу. Я догадывался, что не может быть оно так просто.
« Последнее редактирование: Марта 26, 2016, 01:04:27 am от Bananas »
ЗЫ GTLab 4ever!
« Ответ #37 : Марта 26, 2016, 08:16:43 am »
Нормально сделано.
Так держать.
« Ответ #38 : Марта 26, 2016, 09:17:48 am »
Нормально сделано
- вы это серьёзно? :o  Я здесь вижу традицию DIYstompbox'a - художественная скорлупа снаружи и свалка внутри...
Мой совет: никогда не копируйте чужие компоновки ("лейки"), а разрабатывайте свои, исходя из реально имеющегося пространства.
Не пришивайте пальто к пуговице. Исходите из принципа: сначала - дизайн корпуса, а потом - дизайн платы.
Плату устанавливайте компонентами вверх, печатью вниз - это позволит опустить её максимально низко, не боясь замыканий на корпус.
На критику не обижайтесь.
Успехов!
« Ответ #39 : Марта 26, 2016, 09:46:31 am »
@KSG
Я-то серьезно, а вы?
Может вы представите свою первую примочку на рассмотрение? Она наверняка соответствует всем критериям перфекционизма...
