Автор Тема: Soldano Avenger 1 channel preamp  (Прочитано 3777 раз)
armkon
« : Июня 07, 2011, 03:21:46 am »
Have a little problem with the PSU of Avenger preamp and the biger one with heater.
I will use the transformer without CT:
In 220V, out 1st. 250V 0.03A
2nd. 6.3V 1.66A
Will use the virtual CT: 2x100ohm betwean 6.3V outs of transformer connected to the GND
I'm thinking abuout elevate, or change AC->DC, the heaters but don't know what ist the best way to do it.
Inside the archive there are the pdf file with whole connections, layout and schematic. If anyone can help with it. Please help :)
Layout is design in Sprint-layout.
http://www.onlinedisk.ru/file/675891/
« Последнее редактирование: Июня 12, 2011, 03:24:47 pm от Jimmy_Page »
Re: Soldano Avenger 1 channel preamp
« Ответ #1 : Июня 07, 2011, 10:59:58 pm »
If you have an opportunity to apply a transformer with heater secondary on 9 V and make AC->DC - it wold be better, 'cause you're building highgain. Even not 9 V but about 13.5 V to make 12 V stab using something like xx1084 for pins 4-5, but not 4,5-9.
And don't make virtual CT - that's for power tubes.
If you have not - elevate, but I think it's not a good idea...
Layout:
I don't see a capacitor after rectifier, but there must be. By the way, were is PSU schematic? We must have one to check out.
el Doctor
« Ответ #2 : Июня 07, 2011, 11:27:48 pm »
you can rectify your 6.3V and put a big cap after diode bridge (like 10000mf) - it will looks like regulated PSU, and you will get voltage higher than tubes can stand. But really if you put the tubes you will see that your rectified voltage drops down when you aplly a load to the PSU. It will looks like 6.8-7V jr so, that's ok for tubes.
кот, каторый патом умир.
STOP SMOKING POLYESTER
« Ответ #3 : Июня 07, 2011, 11:38:33 pm »
Like said - try rectifying the heater supply. Rectifier diodes will drop some voltage across themselves, then there are some other issues that lead to non-ideal results, then there is load that will sag the voltage further. Just put the tubes in and measure the actual heater voltage. As long as its between 5.7 and 7V you'll be fine. That's just the easy way.
armkon
« Ответ #4 : Июня 10, 2011, 01:59:55 am »
a little update:
http://www.onlinedisk.ru/file/677888/
2 Questions:
1. heaters, are they ok?
2. i use psu from soldano x88r, can sameone check?
armkon
« Ответ #5 : Июня 13, 2011, 05:30:22 pm »
here is new layout of standard anvenger preamp with output bufer. anyone can verify ?
http://www.onlinedisk.ru/file/680000/
armkon
« Ответ #6 : Июня 14, 2011, 10:48:36 pm »
the schematic of psu is same as the x88r schematic
http://www.onlinedisk.ru/file/680874/
here you have :)
« Ответ #7 : Июня 15, 2011, 08:05:57 pm »
@ armkon, ты говорил, можешь русский читать. А то мне на английском думать дольше .
С накалом намудрил ты что-то...
Питай выпрямленным напряжением все лампы, зачем такой микс выпрямленного и  переменки?
В х88г весь накал сделан переменкой, поэтому там он приподнят над общим проводом. Ты же делаешь выпрямление и фильтрацию накала. В этом случае нет нужды поднимать его над общим проводом.
То есть связка по 150 Ом тоже не нужна.
Кроме того, сейчас у тебя в точку Vref не подаётся высокое напряжение, а она соединена с общим проводом - нужно плюс конденсатора 100u оторвать от общего провода и подключить к точке соединения резисторов делителя 1М-100К.
С заземлением не пойму, что...
Общая  точка должна быть возле минуса первого анодного конденсатора. В эту точку должен обязательно прийти общий провод накала (минус накального конденсатора).
Я обычно разделяю общие провода анодного питания, накала, сигналюный и коммутацию, а соединяю их в общей точке на минусе первого анодного конденсатора.
У тебя анодная змля и сигнальная - нераздельны. Смотри сам.
Ужасная входная цепь: 1М и 68к я бы отнёс как можно ближе к сетке, а к ним от входа - экранированным проводом. У тебя там ещё и анодная цепь рядом, так что нужно это исправлять.
Не пойму, зачем весь первый баллон используется на входе, параллельно два триода, хотя при этом для выходного буфера использован полевой транзистор...  Можно же было буфер сделать на шестом триоде...
Вход LO должен что-то размыкать, а он ничего не размыкает...
На второй лампе каскады расположены наоборот по отношению к схеме, соответственно и обвязка наизнанку идёт - благодатное поле наловить возбудов...
330к после 6 ноги V2 воткнут в землю, а должен идти на 220к 7й ноги V3...
Темброблок не проверял...
Совет такой: найди на форуме SloRectoTwin2 от AZG, печатку к нему, его тут обсосали уже хорошо, изучи и возьми всё, что тебе нужно оттуда. У Avenger схема драйвового канала аналогичная.
А ещё лучше - собирай SloRectoTwin2, будет ещё и чистый в придачу.
« Последнее редактирование: Июня 15, 2011, 08:08:44 pm от Marton »
