Автор Тема: SD Alternative 8 SH-15  (Прочитано 7510 раз)
« : Июля 04, 2008, 11:44:52 pm »
У кого-нибудь есть инфа или звуки? Очень уж аппетитный датчик по спецификациям)
Re: SD Alternative 8 SH-15
« Ответ #1 : Июля 07, 2008, 01:07:40 am »
С форума Дунканов нарыл комментарий от человека из SD:
The SH-15 is a pickup that has to be played to be understood. It's a magnet type most aren't familiar with, and it's a wind spec and wire type that make it very different than other pickups in the Seymour Duncan lineup. There are certain aspects of this pickup that defy common understanding. For example, at 17.7k it's not dark, it has great highs and harmonics. For the A8 magnet it's not harsh or overbearing in the top end either. It's got great attack and punch up front to hit the amp. I have to watch what I say, though, because every Beta Tester saw the potential for this pickup, but many had different reasons for liking it. Some liked it for power rock, some liked that it stayed tight for drop tuning, some liked the way it blasted the front end of a tube amp, and some liked how the Alnico magnet made it integrate tonally with the 59N in a more cohesive manner than say a Distortion for example.
Прорыв? ::)
« Последнее редактирование: Июля 07, 2008, 01:19:05 am от Medved »
« Ответ #2 : Июля 07, 2008, 01:18:04 am »
Еще:
Ok guys, just installed my SH15 Yesterday....
And that's an instant classic ^^
In my Vigier Indus, wanted a replacement for the EVO2 / EVo, which like all the ceramic pickups sounded good with distortion but cold as hell on the clean / Crunch channel. Like most DIMarzio's...
So SH2 in the Neck, And the A8 sounded a good way to have this "warm" duncan sound with enough output to play both heavy and classic rock.
The first thing that was really visible with the A8 is its similarity to the JB.
It's a TYPICAL duncan sound, which is good. Warm, clear, versatile.
But it's NOT a JB. Clearer, it doesn't have this midraneg spike and low end
mudiness. The sound remains clear and over the top, brigt but never harsh.
So if it had to be compared i'd say it's the righ blend between what people expect
from both teh JB and DIstortion. Output, striking rythm one, good cleans, and singing leads.
My guitar is 100% equilibrated, so the pikups response is very clear.
I bet it would sound KILLER in my Les paul, or any mahogany guitar as well, since it
would make the BASS sound both heavy and tight, which only the L500 XL and sh12 do.
In Strat or Tele type giutars, generally bright, one woul probably use 250k pots
to avoid an exagerate treble response, but the pickup isn't harsh so it would prbably work.
In "superstrat" type guitars, which is the case here, it's SO versatile.
Wanna sound like an 1980's shredder ? You will and probably better...
Want to play Classic Rock ? You can, and will get enough FAT.
Like Funk ? Well good match, the Split position is SO bright,
with a sparkling attack, it gives amazing cleans and with my
Qtron awesome funky riffs.
Is there something this pickup can't do ?
Honestly, no. It's probably as versatile as the JB,
and it's Alnco type sound makes it a good match with my
JAZZ but would probably be equally good with a pearly gates or 59,
or full shred...
This pickups, to me, plays in the PRO league ^^
The only pickups i have that sounded THAT good are the
Bill Lawrence L500-L, Screaming Demon, 59 and Super V.
These pickups are not only good at delivering one type of sound
(one trick ponies usually get boring after 1 or 2 months),
but they are also brilliant at giving you any type of sound.
In short, if you need a relpacement pickup, whatever you want,
and even more if you're not sure, go for the A8, you can't go Wrong.
Thumbs up to SD once more, i own 10 guitars and 8 of them now
have SD's (the remaining ones are a tele with stock fender and a
Burny with a Bill Lawrence). Sold all my Dm's, EMG's and others.
In the future.... Well nothing, i finally found the right pickup
for each of my guitars, so i would have to buy one more to try
new pickups ^
Anyway, the goal is to get inspiring intruments that
make you wanna play more and more, and here i am...
Can't put my guitars down, and trust me it seriousely
gets on my girlfriend's nerves ^^
« Ответ #3 : Ноября 12, 2008, 03:52:07 pm »
До нас всегда доходит с опозданием на несколько дней :D
Датчик внушает уже одним своим внешним видом. Поднимает сам себя за отвертку. Одна катушка 9.4кОм, вторая 9.6кОм, в сумме 19кОм. Есть медный экран на катушках. Намотка плотная ярко красным проводом. Сча буду инсталлить :)
Lion
« Ответ #4 : Ноября 12, 2008, 04:47:52 pm »
Что то великовато сопротивлене катушек...
kinoman
« Ответ #5 : Ноября 12, 2008, 04:58:19 pm »
У меня с буржуйским туго, а узнать про звукач охото :D
А почему у катушек разнится сопротивление?Это фича такая?
Shoewreck
  • Даю бесплатные советы.
« Ответ #6 : Ноября 12, 2008, 05:16:39 pm »
Больше похоже на погрешность в пределах допуска, чем на фичу :)
flatcut
« Ответ #7 : Ноября 12, 2008, 06:18:28 pm »
19 кОм- даже чуть больше, чем обещано (17.7). Разное сопротивление катушек- мизер в относительном исчислении, да и СД вроде никогда не стремились делать полностью симметричные хамбы)
Сча струны одену, послушаю датчик напрямую в усилок...
shn
« Ответ #8 : Ноября 13, 2008, 04:16:04 pm »
Вот потому они и "пофанивают" изрядно, и с микрофоном (иногда), коли не стремятся к полной симметрии. Есть один SD, не очень он мне.
Medved, ждем впечатлений!
« Последнее редактирование: Ноября 13, 2008, 04:16:31 pm от shn »
« Ответ #9 : Ноября 13, 2008, 04:29:29 pm »
Миллион раз уже писалось, что разные катушки - ФИЧА. Делается это специально для насыщения звука гармониками. Такие датчики звучат ЖИРНЕЕ. В качестве примера приведу JB, Custom,  Alternative8, Custom-Custom и т.п. от Сеймуров, ToneZone,  D-Sonic и т.п. у Димарзии и т.п. Список можно продолжать. Звукосниматели с абсолютно идентичными катушками звучат суховато, как пример, Distortion у Сеймура и т.п.
« Ответ #10 : Ноября 13, 2008, 05:19:18 pm »
А каким образом "микрофон" связан с электрической несимметрией катушек?
Имхо, "микрофон" - это плохая сборка и эл. параметры датчика тут ни причём. Вроде так.
« Ответ #11 : Ноября 13, 2008, 07:50:36 pm »
Азнаур, ты в какой конфигурации слушал? Поты, темброблок были?
« Ответ #12 : Ноября 13, 2008, 10:23:57 pm »
Слушал с полным комплектом потов на 500к. Гитара - КСП Орижинал серии, дека краснуха, болченый кленовый гриф с палисандром, 24 лада, ТОМ+SB, строй РЕ, струны 10-52 ЭрниБол.
April
  • Handmade rulezzz!!!!
« Ответ #13 : Ноября 14, 2008, 06:50:58 am »
расскажи уже, не томи :)))))
Промышленный электропривод
« Ответ #14 : Ноября 15, 2008, 01:46:06 am »
Впечатления... Просто некуда торопиться, ибо Фрэнк ни разу не обманул и датчик действительно очень и очень необычный. Знакомство начал с чистого звука, да так пока и продолжаю. Гитара Гибсон ЛП '75 Делюкс, кленовый гриф и топ, в неке сш-1н, в бридже тб-15.
Первое впечатление по голому датчику без потов, нагруженного напрямую в простенький двухкаскадный преамп аля бассман на полевичках с очень большим входным:
С гибсоном звучит идеально. Тонально ровный. Такое чувство, что "все на 10". Низа много, середины много, верха много. Динамичный, с высоким разрешением, не грязный, не мутный, не колючий, не пердючий. Все ровно и всего по десять.
После быстрой тестовой нагрузки на два обычных резюка по 470к параллельно, первое впечатление прошло и появилось второе. Верх естественно стал более прилизанным, ушел звенящий презенс, округлилась середина. Добавилось певучести. Стало непривычно и "не так". На том первые тесты решено было свернуть и начать процесс сборки гитары в более-менее рабочее состояние. Процесс закончился вот так:
Фактически, сейчас в гитаре только две громкости, тоны к земле подпаяны, но пока нет кондеров и нет еще одного планируемого тонмода, но я что-то отвлекся ;)
Зато появилась возможность пощелкать тумблером и послушать датчик в сравнении с нековым сш-1 :D
Долгие попытки уровнять датчики по громкости увенчались успехом лишь на половину. Стоит отметить, что нековый датчик у меня фактически фиксирован на уровне рамки из-за особенности гитары, что чуть ниже уровня накладки грифа. Т.е. ближе некуда)
15шка чертовски мощна. Более-менее ровно с неком начинает звучать на расстоянии порядка 4-5 мм от струн.
Теперь звук. Снова чистый. Это что-то с чем-то. Звонкий, но мягкий и не колючий, очень прозрачный, низ плотный и четкий, много середины. Характерный алниковый окрас, диссонанса с сш1 в этом плане нет. А дальше самое удивительное, СШ1 в неке СЛИВАЕТ в детальности и разделению нот в аккорде 19кОмному монстру в бридже :o СШ1 издает заплывающий жиром, переливающийся звук. Густой, весьма размазанный и грязноватый. А8 на его фоне собран, слегка прохладен и кристально чист ::) Так же интересно звучит среднее положение тумблера. Оно выдает не нечто неудобоваримое, как частенько бывает на ЛП, а золотую середину из вышеописанных звуков. Собственно, после внимательного отслушивания среднего положения, желание поставить более "чистый" датчик в нек само по себе отпало.
Итого, первое резюме про удивительный датчик. 19кОм. Мощнейший магнит. Реально неожиданный кристально чистый звук.
По хайгейну может Азнаур напишет, у меня пока данных нет. Да и по чистому, может что добавит интересного, согласится или не очень :D
« Последнее редактирование: Ноября 15, 2008, 01:50:46 am от Medved »
April
« Ответ #15 : Ноября 15, 2008, 10:02:59 am »
Спсб :)
Если будет желание - запиши СХ15 в бдриже, а потом поставть туда СХ1 и тож запиши. с одинаковыми ручками. :) можно уровнять по громкости после записи.
интересно а/б сравнение.
но и так спасибо!
« Ответ #16 : Ноября 15, 2008, 02:50:55 pm »
Не) Ставить в бридж единичку не буду. Долго и гитара не в том возрасте, чтобы с нее постоянно что-то снимать и ставить. К тому же, звук сш1 в бридже и так хорошо известен (тот же сайт СД). Звуки описанной конфигурации запишу чуть попозже.
