Автор Тема: ГУ50 by Manley  (Прочитано 5628 раз)
ГУ50 by Manley
« : Января 14, 2009, 01:50:04 am »
Очень увлекался лампой ГУ50, и, оказывается, был в этом не одинок, даже Великие снизошли до неё:
After the Manley-VTL breakup in 1993, the first Manley stereo amplifier produced at the new Manley Labs factory was the Manley 'Euro' Stereo 100 using the funky russian GY50 output tubes. The GY50 Stereo 100 amplifiers were built from 10/1993 until about 9/1995. There were about 34 of these built carrying serial numbers MANES100001 - 034. You can get the GY50 Stereo 100 Owner's Manual here.
The GY50 output tubes use a 12V heater and were originally used in Soviet tanks, (so the story goes). They are super-rugged tubes and have a whole cage structure that holds them sturdily in their ceramic sockets. We have tons of these in stock, by the way, as we are no longer producing any amps with these tubes...
Basic topology/circuitry of these GY50 Stereo 100 amps was "the same ol' same ol". No surprises here. Input and driver tubes were all 12AT7/ECC81 Yugoslav Ei 9-pin tubes. The chassis was all 1/4" billet aluminum. It looked like this:
I still use one of these GY50 amps at home to drive a pair of little ProAc Super Tablettes on my home-office desktop, and I have had this same set-up for over 10 years with no problems. I never even bother to check the bias. The dang thing just keeps on workin' even though one of the output tube's plates do glow quite red! I replaced the illuminated MANLEY badge with a piece of metal holding two volume controls which are fed by my computer's sound card. So I use mine as a one-input integrated amp. This, one could say, is the predecessor to the next model, the Direct Input Stereo 100/100...
Re: ГУ50 by Manley
« Ответ #1 : Января 14, 2009, 01:58:22 am »
Khaba-khaba
    • ICQ клиент - 272484818
Re: ГУ50 by Manley
« Ответ #2 : Января 14, 2009, 02:41:06 am »
Хотелось бы сделать на них пп оконечник да все никак панельки не найду.
г. Хабаровск [/size]
Re: ГУ50 by Manley
« Ответ #3 : Января 14, 2009, 09:49:28 am »
Получаются отличные басовые усилки:
+900 на аноде, +360 - 2 сетки.
EaNot
Re: ГУ50 by Manley
« Ответ #4 : Января 14, 2009, 10:12:06 am »
GLEB Custom, чем же ты драйверил этих чудищь? Я тоже на заре туманной юности, за неимением других выходных ламп под рукой, возился с ГУ-50. Мне ничем, кроме ФИ аж на паре 6П15П, так и не удалось по-настоящему раскачать их. А звук, если честно, у ГУшек мне не понравился. Ядовитый какой-то, сильно непривычный. И еще момент: дохли как тараканы в твоем аватаре :), если переворачивать аппарат "вверх ногами" при наладке. Конечно, все были БУ, может и полудохлые, но потом в даташите прочитал, что эксплуатация - только вертикально, выводами вниз. Провисающие элементы внутри? А как же тогда применение в оборонке в нестационарной аппаратуре? :-?
Про чудовищный ток покоя в Мэнли не понял, поясни :). Ну 30-35мА на лампу...Поди, анодное у него под киловольт. Мощность на аноде в итоге - паспортная. Ну любил дядька именно такие режимы для ПП, огромное анодное, маленький ток покоя, большая мощность...
« Последнее редактирование: Января 15, 2009, 02:19:45 pm от EaNot »
Re: ГУ50 by Manley
« Ответ #5 : Января 14, 2009, 06:56:54 pm »
EaNot, что-то тебе не повезло, видать.
Tubeman, не поленись, расскажи и про надежность, и про звук, и про раскачку ГУ-50. Особенно, про надежность.
« Последнее редактирование: Января 14, 2009, 10:45:58 pm от olegfx »
Axe
Re: ГУ50 by Manley
« Ответ #6 : Января 14, 2009, 09:08:45 pm »
Драйвер для эффективного использования ГУ делать с низким вых.сопротивлением.Один из вариантов драйверов у меня был сделан на 6П14.Максимально напряжение питания драйвера загонять.Со смещением тщательнее надо быть.Короче копирка тут не идет.На базе ЛОМОшного железа получается 150W/8 ом.
Re: ГУ50 by Manley
« Ответ #7 : Января 14, 2009, 11:45:40 pm »
Axe всё рассказал ;)...
Про ток покоя - в pdf по ссылке выше
Надёжность - выше всяких похвал. Не менял ни разу. У моего приятеля усилители на ГУ50 (Автор - Axe?) работали годами по 6 часов в сутки. Свои лучшие усилители я сделал именно на ГУ50.
Раскачка: ФИ с разделённой нагрузкой, а после него - драйвер на 6Н6П. Вроде бы Axe (если не путаю) делал драйвер с разделённой нагрузкой на 6П14П :) А вообще они оживают после 700В на аноде.
Axe
Re: ГУ50 by Manley
« Ответ #8 : Января 15, 2009, 03:56:46 am »
Не по 6,а по 12 часов.На 6П14  один из вариантов.Были на 6Н8С,высоковольтный диф.каскад на транзистарах(Peavey вариация),в катод качал (Music Man) и даже на основе каскада для осциллографа(зацепила фраза в статье "легко получить 100в переменного напряжения) и его туда же,короче порезвился.
VALUE
    • ICQ клиент - 395380114
Re: ГУ50 by Manley
« Ответ #9 : Января 15, 2009, 12:13:49 pm »
Глеб, а со строчными не экспериментировал?
В частности с 45-ой.
что-то захотелось конец собрать, ватт под 700-800... или кило.
Лампочки линейные, низкоомные...
Желание возникло после того, как принесли на ремонт усил на 6-ти 6П44С.
Вот он качал здорово, и низы обалденно играли, учитывая то, что выходные лампы севшие были...
Куда там профессиональным биполярникам и мосфетам...
Есть идея бестрансформаторно кормить - на анод удвоение от сети. Экранки - выпрямление сети.
Естественно трансформаторный фазик с гальванической развязкой.
EaNot
Re: ГУ50 by Manley
« Ответ #10 : Января 15, 2009, 02:26:02 pm »
В пдф-ке по ссылке и сказано - 30-35мА на лампу. Что ты нашел тут чудовищного??? Потому и прошу пояснить.
Спасибо. Ну а вверх ногами-то запитанный усилок переворачивал при наладке? Ничего с ГУшками? Или все же мне такие попались...
« Последнее редактирование: Января 15, 2009, 02:26:40 pm от EaNot »
Re: ГУ50 by Manley
« Ответ #11 : Января 16, 2009, 01:14:29 am »
Были 6п45с, а теперь их днём с огнём не сыщешь...
Лежит у меня усилок на 45-х буду переделывать на 6Р18 или ГУ.
30mA это жутко неэкономично ;D
Я не переворачивал, а вот усилок Axe 4хГУ50 работает уже несколько лет вверх ногами.
Axe - гуру ГУ50
« Последнее редактирование: Января 16, 2009, 01:15:18 am от GLEB »
Axe
Re: ГУ50 by Manley
« Ответ #12 : Января 16, 2009, 02:25:13 am »
Мгновенное просветление наступает при ударе в 950 вольт
Re: ГУ50 by Manley
« Ответ #13 : Января 16, 2009, 08:17:14 pm »
Аминь, есть ли у кого новости по ГУ29?
