Автор Тема: Радиоэпоха  (Прочитано 2482 раз)
Радиоэпоха
« : Апреля 11, 2020, 02:52:07 am »
Наткнувшись в Инстаграме на коллекции удивительных старинных радиоприёмников, был поражён их разнообразием и дизайнерским креативом. Не могу не поделиться :)
https://www.instagram.com/p/B-xf6SHA3RN/
https://www.instagram.com/p/B-z4xqOAJWt/
https://www.instagram.com/p/B-slataAp86/
https://www.instagram.com/p/B-slFG1AlOa/
https://www.instagram.com/p/B-pblv1gMHM/
https://www.instagram.com/p/B-h5TEQAZP1/
https://www.instagram.com/p/B-aIgv4gum4/
https://www.instagram.com/p/B-Skl6JA_gY/
https://www.instagram.com/p/B-P3W4eA8tV/
https://www.instagram.com/p/B-P27w6A0_W/
https://www.instagram.com/p/B-KxTylggt8/
https://www.instagram.com/p/B-Kv4ZvAVoF/
https://www.instagram.com/p/B963_kMArwP/
https://www.instagram.com/p/B9zvN3ZAm9A/
https://www.instagram.com/p/B9uCizIAiDc/
https://www.instagram.com/p/B9p4TnlAkWs/
https://www.instagram.com/p/B9nKf4yA29w/
https://www.instagram.com/p/B9b3hbsgibW/
https://www.instagram.com/p/B9ZgYCwg1Qe/
https://www.instagram.com/p/B9SKnUmgXj0/
https://www.instagram.com/p/B9EgkblgBQd/
https://www.instagram.com/p/B9C0gj4gtuD/
https://www.instagram.com/p/B89sNYWAU9I/
https://www.instagram.com/p/B87D3XXAt2v/
https://www.instagram.com/p/B8hCcPrgRJX/
https://www.instagram.com/p/B8bw2UJAp4B/
https://www.instagram.com/p/B8W2Bsyg2up/
https://www.instagram.com/p/B8SNBtoA-kh/
https://www.instagram.com/p/B8KHL0Igkpf/
https://www.instagram.com/p/B8Gy8cpAOus/
https://www.instagram.com/p/B8B_lv0gYKx/
https://www.instagram.com/p/B76IQgEAY3f/
https://www.instagram.com/p/B71ZS41A8On/
https://www.instagram.com/p/B7oa1AaA3cx/
https://www.instagram.com/p/B7l2TYhA3zt/
https://www.instagram.com/p/B7d1RbxAtPi/
https://www.instagram.com/p/B7ZbdE_AVas/
https://www.instagram.com/p/B7RT7rRg0WQ/
https://www.instagram.com/p/B63yCHggnlK/
https://www.instagram.com/p/B6OlAWfANL-/
https://www.instagram.com/p/B6BrG4uAAmC/
https://www.instagram.com/p/B6BL4OIg12X/
https://www.instagram.com/p/B58DzXOg6W1/
https://www.instagram.com/p/B536awtgHqb/
https://www.instagram.com/p/B5nVUxNAwTd/
https://www.instagram.com/p/B5ic3nTl5nO/
Можаев
  • Вот она какая
Re: Радиоэпоха
« Ответ #1 : Апреля 11, 2020, 12:25:01 pm »
Последняя картинка хороша
« Последнее редактирование: Апреля 11, 2020, 12:26:02 pm от SM »
Создатель МС-ПЕРЕГРУЗ
Re: Радиоэпоха
« Ответ #3 : Мая 14, 2020, 06:55:32 pm »
Лампотестер Centrad 751
https://www.instagram.com/p/CAGoxUOJu6K/
Вопросительный знак означает, что лампа "дутёзная", то бишь сомнительна и её рекомендуется заменить :)
Re: Радиоэпоха
« Ответ #4 : Мая 16, 2020, 01:02:51 pm »
Re: Радиоэпоха
« Ответ #5 : Мая 25, 2020, 06:19:03 pm »
Кропотливое восстановление после рукоблудия предыдущего владельца (везде стопка картинок):
https://www.instagram.com/p/B9yA2ndpE4v/
https://www.instagram.com/p/B-U5bYvJGc_/
Финал работы ослепителен:
https://www.instagram.com/p/B_aLIg1JqCb/
patron
Re: Радиоэпоха
« Ответ #6 : Мая 28, 2020, 09:46:19 am »
Только недавно восстанавливал Симфонию 003 из состояния зомби  :)
Выглядит конечно завораживающе - особенно ночью.
Проблема только одна - все старые приёмники работали на диапазонах ДВ - СВ - КВ , на которых нынче в городе ничего кроме грррррр - хрррррр - жжжжж не услышишь  :-/
Пришлось встроить маленькую платку с диапазоном FM, чтоб хоть как-то можно было использовать аппарат.  Приёмник на микросхеме ТЕА5711, перестройка частоты варикапами, управляемыми напряжением с переменного резистора. Поскольку перестройка обычным потцем слишком грубая применил 10-ти оборотный резистор Bourns-3590s-2-203l. Перестройка плавная. На ибее их полно.
Re: Радиоэпоха
« Ответ #7 : Мая 28, 2020, 11:27:56 am »
Когда-то я делал конвертеры на диапазон 27 мГц с настройкой варикапом и меня удручало отсутствие шкалы, пока не догадался поставить на цепь управления варикапом стрелочник от магнитофона - хоть какая-то, но шкала... :)
patron
Re: Радиоэпоха
« Ответ #8 : Мая 28, 2020, 12:29:32 pm »
Есть несколько вариантов решения, чтоб использовать родную шкалу приёмника.
Одно такое решение применено в приёмнике VEF214 : КПЕ, кроме обычных секций с большим числом пластин имеет ещё дополнительные секции с малым числом пластин и малыми ёмкостями - его можно использовать вместо вариакапов.
Другое решение - переделать верньер так, чтоб он крутил ещё и ось многооборотного переменного резистора, управляющего варикапами.  Вот до переделки и после :
Ниже большого чёрного шкива видна ось переменного резистора, на которую заходит нить верньера.
« Последнее редактирование: Мая 28, 2020, 12:36:25 pm от patron »
Re: Радиоэпоха
« Ответ #9 : Мая 28, 2020, 03:11:22 pm »
Элегантное решение, респект :)
Re: Радиоэпоха
« Ответ #10 : Июня 21, 2020, 01:35:03 pm »
Re: Радиоэпоха
« Ответ #11 : Июля 19, 2020, 09:20:13 pm »
Не знаю как насчёт звука, но дизайн потрясный:
https://www.instagram.com/p/CCo1eYMH1WM/
Re: Радиоэпоха
« Ответ #12 : Июля 21, 2020, 12:01:04 pm »
Стопка из 6 картинок. Удивительное дело, но на заре транзисторной эры выпускались однотранзисторные приёмники по рефлексной схеме. Всегда считал, что это чисто радиолюбительское изобретение...
https://www.instagram.com/p/CClmkpfJrYY/
Re: Радиоэпоха
« Ответ #14 : Октября 03, 2020, 11:15:51 am »
Винтажный преамп на сверхминиатюрных лампах (8 картинок, русский перевод):
https://www.instagram.com/p/CE_WDciDgUz/
Re: Радиоэпоха
« Ответ #15 : Ноября 15, 2020, 02:02:18 pm »
Таких динамиков я в жизни не видел :D:
https://www.instagram.com/p/CHYtVyBJE4w/
(картинки 4...7)
Re: Радиоэпоха
« Ответ #16 : Ноября 15, 2020, 03:34:39 pm »
(картинки 4...7)
Я видел динамики в форме прямоугольной трапеции с диффузорами из вспененного пластика. Стояли они в "эстрадном" Ямаховском аппарате 70-х годов. Жаль, не сфотал...
Re: Радиоэпоха
« Ответ #17 : Ноября 15, 2020, 04:04:49 pm »
Вот тут коллекция подобных монстров, включая и rotary speakers :):
https://www.ozvalveamps.org/yamaha.html
Re: Радиоэпоха
« Ответ #18 : Ноября 16, 2020, 05:27:39 pm »
Ага, оно!
Re: Радиоэпоха
« Ответ #19 : Ноября 20, 2020, 06:58:17 am »
