Автор Тема: 1W poweramp  (Прочитано 8467 раз)
armkon
1W poweramp
« : Апреля 15, 2014, 08:01:01 pm »
Hello, sorry for english toppic but i have a problem. I see a lot of smart guys in here so i think that i will ask for something.
I have design a little PA 1W or something like this. It will be powered by nixie PSU.
It will use normal input stage then cathodyne on 1 ecc83 tube and signal will be outputed from ecc82 tube thru transformer.
It will be used to connect external preamp and 9v eq betwean it and PA. I think that ecc82 tube will be drived with good signal streanght that will be loose on eq and will go up on that first stage...
Or it's bad idea?
Maestro
Re: 1W poweramp
« Ответ #1 : Апреля 15, 2014, 08:50:28 pm »
Ёмана! упражняемся в буржуйском )
@ armkon
Put here what type preamp(or scheme) you want to use, and type Eq(or scheme) for full image of your plan. I think it's would be better to understand your question for people here.
ФёдорЫч
  • Long live Rock-n-Roll!!!
Re: 1W poweramp
« Ответ #2 : Апреля 15, 2014, 08:58:41 pm »
Seems to me , the idea is quite strange. Why did you take a decision to use this 1watt PA . Do you need  to have output signal to be distorted  ( like guitar amp sounding ) or clean ?  Your schematic diagram has the error . Feedback resistor R11 must to be connected to point R1-C1-R7.
sk
Re: 1W poweramp
« Ответ #3 : Апреля 15, 2014, 09:18:50 pm »
И не надо на сетках и катодах выходных ламп писать 300V.
armkon
Re: 1W poweramp
« Ответ #4 : Апреля 15, 2014, 09:27:37 pm »
IT must act like normal guitar amp. preamp will be higain something engl like, i want to use it for playing at house. As Post EQ i want to use MXR EQ.
Sorry for my mistake with that 300V...
« Последнее редактирование: Апреля 15, 2014, 09:45:57 pm от armkon »
ФёдорЫч
Re: 1W poweramp
« Ответ #5 : Апреля 15, 2014, 09:42:19 pm »
Triod in PP output stage is not for guitar good sounding amps. The sound will be dull and rigid.  Pls, look here
http://www.liegamp.com/pdf/stimer.pdf
« Последнее редактирование: Апреля 15, 2014, 09:51:06 pm от GREtchko »
Gregg
Re: 1W poweramp
« Ответ #6 : Апреля 15, 2014, 10:26:27 pm »
I agree with you that push pull small signal triode based amp is not a good idea but single ended pentode or triode design is even worse.
armkon
Re: 1W poweramp
« Ответ #7 : Апреля 15, 2014, 10:47:46 pm »
So what is better idea ? Then push pull as poweramp for playing at home with good sound quality?
I can build a TBA820 amp like in engl e530.
Waiting for your sugesions  ;D
Gregg
Re: 1W poweramp
« Ответ #8 : Апреля 15, 2014, 10:52:02 pm »
My advice is get some 6П30Б or 6П30Б-Р subminiature pentodes from ebay or elsewhere and make a regular push-pull class AB power amp as are most of the guitar amps. Depending on the anode voltage you'll be able to get somewhere between 2 and 6 Watts RMS before clipping.
ФёдорЫч
Re: 1W poweramp
« Ответ #9 : Апреля 15, 2014, 10:56:29 pm »
http://vk.com/gtlab
 The samples are here. SE amp , 2,2 watts . This amp
http://vk.com/albums183961254?z=photo183961254_305267337%2Fphotos183961254
« Последнее редактирование: Апреля 15, 2014, 11:09:25 pm от GREtchko »
armkon
Re: 1W poweramp
« Ответ #10 : Апреля 15, 2014, 11:08:37 pm »
[/quote]
http://vk.com/gtlab
 [/quote]
i don't see anything when i going in to this page
ФёдорЫч
Re: 1W poweramp
« Ответ #11 : Апреля 15, 2014, 11:12:53 pm »
In audio (аудиозаписи) , song BB stars-slow  and the next (below)
Re: 1W poweramp
« Ответ #12 : Апреля 15, 2014, 11:19:06 pm »
ФёдорЫч, тем кто не присутствует в контакте не посмотреть, я например не нашел.
ФёдорЫч
Re: 1W poweramp
« Ответ #13 : Апреля 15, 2014, 11:21:57 pm »
А я не умею по другому :( :( Только через "В Контакте"
« Последнее редактирование: Апреля 15, 2014, 11:23:21 pm от GREtchko »
ФёдорЫч
Re: 1W poweramp
« Ответ #15 : Апреля 15, 2014, 11:56:30 pm »
I can to send samples  to e-mail address. If you want.
armkon
Re: 1W poweramp
« Ответ #16 : Апреля 16, 2014, 12:11:26 am »
I have send you PM, waiting :)
armkon
Re: 1W poweramp
« Ответ #17 : Апреля 16, 2014, 12:14:42 am »
What do you think? It's worth to try? How to make this PA better then in is in this configuration ? ::)
PA like fireflywork good for me, i know it's not the best think that i can make but it's ok and better then making an ic based pa...
« Последнее редактирование: Апреля 16, 2014, 10:16:21 am от armkon »
armkon
Re: 1W poweramp
« Ответ #18 : Апреля 16, 2014, 01:55:49 pm »
A little layout for this push pull amp:
Don't look at input tracks.
If anyone can check it please any help will be welcome :) ;)
« Последнее редактирование: Апреля 16, 2014, 01:56:37 pm от armkon »
Re: 1W poweramp
« Ответ #19 : Апреля 16, 2014, 02:41:27 pm »
armkon, try to check this schematic of the power amp, I think it's better solution for the guitar sound.
http://forum.guitarplayer.ru/index.php?topic=253490.msg7372516#msg7372516
